I design irrigation systems ( amongst a whole bunch of other things ) using AutoCAD LT 2014, an dI find I need to draw lots of concentric circles, I have two screen and read a figure on one screen and set the radius of that circle I need on AutoCAD on the other screen. So, my question is;
Is there a way to automatically have Autocad read a table in excel and draw the concentric circles at a given point, using the radii in the excel worksheet?
Thank you in advance to any and all help recieved 🙂
Solved by pendean. Go to Solution.
Solved by braudpat. Go to Solution.
Hello
A quick answer !
You could use Script files generated from Excel and edited with the notepad ... to get things like that :
_CIRCLE 1000,1500 50
_CIRCLE 1000,1500 70
_CIRCLE 1000,1500 100
_CIRCLE 1000,1500 150
This .SCR file (of 4 lines) will draw 4 circles with different radius : 50, 70, 100, 150
Patrice BRAUD
Thank you very much to both Braudpat and Pendean for your replies. they have helped me in a very big way and will speed up my designing no end:)
