Newbie here. I have an alignment drawing that I'm xrefing into a sheet drawing. The sheet drawing is an overall plan and I'd like to turn off the display of minor station labels to help readability. I've gone into Toolspace>Settings>Alignment>Label Styles>Station>Minor Station and set the label visibility to False. The labels are still appearing though. Any thoughts would be appreciated.
Solved by Lisa_Pohlmeyer. Go to Solution.
You could try removing the minor station labels. Select the alignment, hit "edit alignment labels" and delete the labels.
Thanks! That worked. I was thinking that label styles worked like a text style insofar as you could change the properties of them when xrefed into a separate drawing.
