Civil 3D Forum
Label Leader Attachment
4 REPLIES 4
Rainman1
1886 Views, 4 Replies
Please see attachment. There are two structure label styles in the attachment. The one on the bottom has the leader attached to the edge of the structure and the one on the top has the leader attached to the centre of the structure. How do I change the attachment point for the top label so the leader attaches to the edge of the structure as the bottom label does? Can't seem to find the parameter to change??
4 REPLIES 4
AlmasSuljevic
in reply to: Rainman1
Any chance one of those two (top one) is just plain leader with turned off the leader visibility. In all versions I tried it points to the edge of the structure and no place to adjust it in the style settings. I guess, you got this far, too. Smiley Happy
See this:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Leader-attachment-to-pipe-structure/td-p/3551768
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
gccdaemon
Is the problem manhole a block or a structure using a block reference? If it is a structure, is it only a hatch in the structure block? Also, as our friendly autodesk professional stated, it could be a generic label with reference text, which would update like it's supposed to and not be placed propperly.
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
ArchD
in reply to: gccdaemon
Does the one pointing to the center have the point style set to none? Is the solid red circle a basic object, or apart of the point style?
For me, if the point style is set to none, then the point label will point to the actual point when in dragged state. If you set the point style to use that red circle as the point style, it would take into account that object and offset the leader head.
Archie Dodge
Applications Expert - Infrastructure Solutions Division
IMAGINiT Technologies
Rainman1
in reply to: ArchD
Point? Point style? There is no "point" in the style.....or "point" settings???????
Rail Community
