On Wed, 9 Jan 2008 23:01:21 +0000, libbybapa <> wrote:
>At work I use an HP xw9000 workstation with a dual-core AMD opteron 2.00 GHz, and 4 GB of ram (recognizes 3.5 GB) using XP and NVIDIA Quadro FX 1500 graphics card. 3GB switch is enabled.
>At home I use an HP Pavilion Media Center (forget the number off hand) that is equipped with an AMD dual-core Athlon 2.20 GHz processor and 2 GB of ram using XP and an ATI All-In-Wonder graphics card.
>My machine at work, despite being a "better machine" is much slower and crashes significantly more frequently. At home, when running ACA and watching the tsk manager, the CPU usage will often run 100%, accomplishing tasks quicker and more consistently than at work where the processor basically stops at 50%, takes longer and often crashes. It seems unable to do any rendering without crashing. Watching the task manager it looks like it maxes out the memory and a fatal error results. My home machine with 1/2 the memory renders the same files just fine without error. Any suggestions for configuring the work machine to actually work?
"Lesser" home machines are often peppier because they do not have the network
overhead. Untweaked, XP can be a real network hog. Have you tried working
locally at work (copying files to the machine) to see if that is an issue?
Also, are you comparing the same exact files?
Matt
mstachoni@verizon.net
mstachoni@bhhtait.com
