Is there anyway of starting a session of AutoCAD with the find and replace fields already populated? We have always struggled with superscript 2 and 3 when imported from MS word and have to use the find and replace;
FIND: M2
REPLACE: M\u+00b2
We used to have a VB routine that would scan the entire drawing and do the replace for us however VB failed to run on ACA 2012 and we were left with the above as a solution.
Many thanks
Ben
Solved by Victoria.Studley. Go to Solution.
Hi Ben,
Dean is correct - there isn't any functionality in the program to do this at the moment. However, if you'd like to see it in a future update or release, you may want to voice that directly the Product Team, via the Product Feedback Page.
