Can you explain me what I do wrong? http://www.youtube.com/watch?v=40Yw2rRY8xw&feature=plcp I cant set the hatch in quick cross section in the wall. I have installed sp1 for ACA 2013. It nothing change. I'm architect from Poland.I use Autocad Architecture five years. I get active subscription. In ACA 2012 this problem not exist.
another error. I can't copy to clipboard my styles that was created in ACA 2012
see the video
http://www.youtube.com/watch?v=u4pU71kg1aQ&feature=youtu.be
applies to walls, doors, stairs, slab , multiblocks created in ACA 2012. Even when I'm saving the file as 2013 dwg.
Now I'm in bad situation. I have changed all my projects to 2013 dwg ver. Autocad Architecture 2012 now is unusable.
All of my files, styles, palets and AEC objects are now in 2013 format. I have to work but I can't.
I can't use local edition. the walls disappeared.
see video.
Can You explain me, what have You done with this ACA in version 2013. It's worse than ACA 2012!
Can You give me a program to change back ACA 2013 to ACA 1012 without compatible problem?
ps. it's not even all the errors that I found.
