Solved by jorgeseptien. Go to Solution.
I have the same problem, the dim style and text style are annotated in the original drawing, when I add it to the tool palete its not. I'm using 2010
I been trying to find a way to make work with no luck so far..
I'm trying to do the same thing with the same exact results. My source drawing has everything just the way we need it, including the annotation option turned on. When I open a new drawing that does not have the dimension style in the drawing and use the Linear Dim from the tool palette, the newly created dim style is not annotative.
Anyone have any luck getting this to work?
We're in C3D 2011 - 64bit
This is an old bug that I reported on years ago to deaf ears. Tool Palettes came out before Annotative Scaling was introduced and the option for storing the Annotative Scale setting just hasn't been incorporated. It doesn't work for Text Styles either. It does work with Mleader Styles.
The whole logic behind storing Text and Dimension Styles as part of a Tool on a Tool Palette is pretty limited. Once you drag a dimension style over to a Tool Palette, the style settings are coded with the Tool and there is no connection to the original style or the drawing. Anyone who has developed standards for any firm knows that it is far better to manage styles through a source file. It would have been really nice if Autodesk would have offered an option to pull a style from a source file.
To remedy the problem being described in this thread, you need to find a way to import the Dimension Style from the source drawing. The easiest way is to make a Tool that inserts the source file. I found that the Annotative Scale setting comes through as a Block. You can make a Tool that simply inserts a drawing file that only contains the Dimension Style you want.
In my own work I took it a little farther and wrote a lisp routine that inserts the Block, sets the DimStyle, Text Style and Mleader Style current and then Purges the Block. This way anyone in the office with basic skills can update or improve on the basic settings without having to know any code.
There is a way to overcome this problem. You can follow these steps:
1) copy the linear dimension to the tool pallete
2) right click over the icon -> properties...
C^C-dimstyle an;yes;MyDim;yes;r;MyDim;dimlinear
The name of my dimension style is "MyDim", then it's the only thing you have to change on the script (command string).
Now the style can be annotative as desired.
Great
I do have some issue.
My dimension style has an alternative dimension (principal is on m and second is on ft (architectural) once i use it in other file the architectural alternative style is missing (it calculate but instead of displaying ft and inch it only display the number)
@Anonymouswrote:There is a way to overcome this problem. You can follow these steps:
- Use flyout -> No
- Command string ->
- Ok
