I've attached a file with a 2D elevation. The hidden lines are created as continuous lines. This always worked fine in previous releases. Is this a bug or have I done something wrong?
Solved by O.Maille. Go to Solution.
Solved by barbara.schurig. Go to Solution.
Oh wow I have the same problem. glad I found others are running into it to. Tooks me weeks just to find the right forum. Hope this is resolved!
Herman,
Can you post the link? Could not found it in update section.
tks
The hotfix was with a responce from my subscription Autodesk support team.
I'm not sure if I can post it on this site.
I would have expected to find it in "AutoCAD Architecture Services & Support" updates & downloads but it is not there at this time.
I think the Autodesk support team will know what operation system hardware you are using.
Herman,
I am using windows 7, 64 bits. Are you using the same? I realy need this fix as soon as possible.
tks!
you can read here, but attention, it is the german version.
Hello All,
This issue is one we have been working diligently on and have developed a hotfix that will be released very soon. Please be on the lookout via your communication center notifications (top right of UI), Subscription Center, and the support landing page for ACA on www.Autodesk.com. Thank you.
The Hotfix is now available at our website.
Please check out this link:
Section Hotfix 2013 ACA AME
This works for AutoCAD Architecture and AutoCAD MEP 2013 and all languages.
Best regards,
Barbara
The hotfix did not work for me. I followed the instructions and now none of my AEC objects work and I can't load the content browser. I removed the hotfix and everything is back to the way it was. Has this hotfixed work for anyone else?
So far it has worked on all of my tests.
My machine = Windows 7, 64 Bit. English version of ACA.
I tested it with W7 64-bit German and English release. The hidden objects are not visible and also Content Browser pops up as usual, I can search and drop objects into a palette.
Barbara
This hotfix works for all languages. There is no "English" or "German" version, I just want to clarify this so no one gets confused.
All of you can use the hotfix in the AutoCAD Architecture or AutoCAD MEP 2013 download area, no matter what languages you are using.
Cheers,
Barbara
I doubt that would be the name of the folder
"C:\Program Files\Autodesk\AutoCAD 2013."
just picking !!
the folder name is correct. With 2013 release AutoCAD Architecture and AutoCAD MEP had been modified and several AEC related files are now stored in the AutoCAD folder.
The benefit of this is, a much faster installation when AutoCAD Architecture or MEP are installed on a system where AutoCAD has already been installed. Or if AutoCAD Architecture was installed, MEP installation will run so qiuck that you might doubt that everything installed.
Cheers,
Barbara
