Weird behavior when working with “block table”,
I wanted to create simple shape for rectangle such that its dimensions are selected from the block table. For that purpose, I have constructed the required constrains (geometric and dimensions) and then a “block table” (attached).
As I tested the behavior to have 1X2 rectangle (attached), I got a rotated one (attached)!
What might be the issue here?
Thank you
Best
Jamal
No idea. The pictures are nice and helpful to demonstrate what you are seeing but a solution resides in having the actual Block to review.
Please post the Block.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Many thanks Charles for the answer.
I got help from a colleague who advised to add “perpendicular constrains” (in addition to the coincidence) at three corner of the rectangle. It works fine (attached)
Best
Jamal
