Hello Team,
My system config :
Windows7
IIS7.5
We have hosted our webdav server on IIS7.5
My problem :
When i try to save dwg file from webfolders , I am getting this error as... file is used by another sesssion and so the changes are saved to tmp file.
I have sample application without webdav , there saving is working fine without any issues..
Problem is only when i try to save via Webdav
i referred :
http://forums.autodesk.com/t5/AutoCAD-2013-2014-2015/Unable-to-save-AutoCAD-Files/m-p/3530024#M3510
tried everything that is mentioned in this post.
some said this might be because of antivirus , even after disabling antivirus in my system no use.
I checked permissions, have given full control on the users.
Tested in licensed version of AutoCad2014. still no use.
checked with locks on files ..all files are locking and unlocking properly . No issues there .
In my application only dwl & dwl2 files are created and then my changes are saved to .tmp file.
Thats all. No .bak file is created.
Now i donno what else i need to check.I donno how to proceed also.
Please help .. what else need to be done. ??
NOTE: I tried to attached charles and fiddler recording but i guess these files are not supported.
No in my case log in rights and access to drive are correct.
Because we are also having a functionality where in we do editing of ms documents via webdav.
when we do editing from MAC OS, the saving procedure of document from mac machine is much similar.
moves changed content to tmp
deleted original copy
renames tmp file to original name.
This is working fine . and also i verified the permissions from system admin. every thing is correct . Full control is given.
as per GegH1 reply from this link.
this is latency issue. if it is latency issue then how can i check this. ??
What else i need to do .. ? this issue is eating my time
Please
