Hi All,
when I draw revision cloud it always creates new layer, how can I switch off this?
Solved by nestly2. Go to Solution.
Welcome to the Autodesk forums
Are you using "vanilla" AutoCAD, or one of the vertical products such as AutoCAD Mechanical. If "vanilla" then there must be some command customization as the standard REVCLOUD command will draw the revcloud on the current layer just as it would a line or circle. Might you be using a lisp or launching REVCLOUD from a tool palette?
We are using AutoCAD MEP 2013.
I noticed that revision cloud placed in toolbar has different command which is ANNOREVISIONCLOUDADD, I didn't know that becouse I always typing REVC and this problem was on my colleague's computer. Now I know it was nat a problem, just different command.
I need read about this ANNOREVISIONCLOUDADD command, what is it for 😉
Many thanks nestly for Your help 🙂
