I'm trying to export some DWG from a lareg DWG to a smaller one to be linked in to Revit. But I can't get the EXPORTLAYOUT command to work. I get an unhandled error exception
I've tried savingto the server (remote hosted over VPN) and to my own Desktop, makes no difference.
Any ideas out there?
"eNotAllowedForThisProxy"
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
Autodesk.AutoCAD.Runtime.Exception: eNotAllowedForThisProxy
at Autodesk.AutoCAD.ExportLayoutUI.Commands.ExportLayout()
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.PerDocumentCommandClass.Invoke(MethodInfo mi, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.34011 built by: FX45W81RTMGDR
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Acdbmgd
Assembly Version: 19.1.0.0
Win32 Version: 19.1.108.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AcdbMgd.DLL
System
Win32 Version: 4.0.30319.34003 built by: FX45W81RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
AdApplicationFrame
Assembly Version: 0.0.0.0
Win32 Version: 4.0.19.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AdApplicationFrame.DLL
AdWindows
Assembly Version: 4.0.36.100
Win32 Version: 4.0.36.100
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AdWindows.DLL
PresentationFramework
Win32 Version: 4.0.30319.34004
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
Win32 Version: 4.0.30319.34004 built by: FX45W81RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
PresentationFramework.Aero2
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero2/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero2.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
accoremgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/accoremgd.DLL
Acmgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/Acmgd.DLL
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
AcWindows
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AcWindows.DLL
AcCui
Win32 Version: 19.1.18.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AcCui.DLL
PresentationFramework-SystemXml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
WindowsFormsIntegration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
AcWindows.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcWindows.resources.DLL
System.Windows.Forms
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
PresentationUI
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll
System.Xml.Linq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
PresentationFramework-SystemXmlLinq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
UIAutomationTypes
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
ContextualTabSelectorRules
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AcWindows.dll
PresentationFramework-SystemCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll
Microsoft.Expression.Interactions
Win32 Version: 2.0.20520.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/Microsoft.Expression.Interactions.DLL
ManagedMC3
Assembly Version: 7.2.0.0
Win32 Version: 7.2.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/ManagedMC3.DLL
AcAeNet.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcAeNet.resources.DLL
AcButterflyExt.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcButterflyExt.resources.DLL
AcCloudRender.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcCloudRender.resources.DLL
AcCustomize.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcCustomize.resources.DLL
AcDxWizard.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcDxWizard.resources.DLL
AcExportLayoutUI.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcExportLayoutUI.resources.DLL
AcInterfere.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcInterfere.resources.DLL
AcLayer.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcLayer.resources.DLL
AcLayerTools.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcLayerTools.resources.DLL
AcMrUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcMrUi.resources.DLL
AcMultiLineUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcMultiLineUi.resources.DLL
AcRecoverAll.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcRecoverAll.resources.DLL
AcScaleList.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcScaleList.resources.DLL
AcUnderlay.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcUnderlay.resources.DLL
AcViewTransitionsUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcViewTransitionsUi.resources.DLL
AdskConnectionPointMgd.resources
Assembly Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AdskConnectionPointMgd.resources.DLL
AcCalcUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcCalcUi.resources.DLL
AcLayer
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AcLayer.DLL
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
AcMr
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AcMr.DLL
System.Runtime.Serialization
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
AcLivePreviewContext
UIAutomationProvider
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
PresentationFramework.Luna
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Luna/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll
AcMrUi
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AcMrUI.DLL
AcDialogToolTips
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AcDialogToolTips.DLL
AcDialogToolTips.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcDialogToolTips.resources.DLL
AcExportLayoutUI
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AcExportLayoutUI.DLL
AcExportLayout
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AcExportLayout.DLL
AcExportLayoutEx
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AcExportLayoutEx.DLL
AcTaskDialogs
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AcTaskDialogs.DLL
AcTaskDialogs.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcTaskDialogs.resources.DLL
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
Does this happen with one (or just a few) DWG file(s) in particular, or with any (all) file(s) with which you use the command?
Assuming it's only one (or a few), and based on the existence of the word "proxy" in the error code, I'm going to guess that the error is related to a custom object (or objects) in the DWG for which you do not have the creating application, and possibly no "enabler" installed either. For more info, see:
Some things to check and try:
Do you have PROXYNOTICE turned "on" (=1)?
Do you have PROXYSHOW turned "on" (=1 or 2)?
Is PROXYGRAPHICS turned "on" (=1) in the DWG?
Do you have DEMANDLOAD turned "on" for objects and commands (=3)?
If you are able to determine that there are custom objects (or proxies) in the DWG(s), then it might help to download and install one or more object enablers. If so, you might find what you need with this link:
Hi dmfrazier, thanks for your answer
You wrote about proxies, so while opening the file I chose not to show proxies. This made no difference.
So then I opened it again chosing to show proxy graphics to check through your list:
Yes, =1 - Do you have PROXYNOTICE turned "on" (=1)?
No, =0 - Do you have PROXYSHOW turned "on" (=1 or 2)?
No, =0 - Is PROXYGRAPHICS turned "on" (=1) in the DWG?
No, =0 - Do you have DEMANDLOAD turned "on" for objects and commands (=3)?
All those nos confuse me, I chose to have them shown.
I'm new to proxy graophics, but as I understand it I have two options. Or I can install an/some object enablers. But how do I know which ones I need?
I've also read that I can export the file to a new DWG losing all blocks and 'exploding' all proxy graphics. But DWG is not an option under Export. So I don't quite understand this option.
What I'm trying to do is have a Layout set up where I can export every now and then as the project progresses, to my Revit collegues. They complain that otherwise the file is to big (geometrically) and contains lots of distracting information (layers) not relevant to their purpose.
"I'm new to proxy graophics, but as I understand it I have two options. Or I can install an/some object enablers. But how do I know which ones I need?"
With ProxyNotice turned on, you should see (in the notice) which "applications" are missing (if any). You can use this as a guide, but it might be simpler to just download and install all available Enablers for your version.
Bear in mind that my advice here is based on a "working hypothesis" (that the error is related to a custom object - or objects - in the DWG for which you do not have the creating application, and possibly no "enabler" installed either) which may very well be incorrect. The only way to find out is by testing the hypothesis. There are certainly other possible explanations.
"I've also read that I can export the file to a new DWG losing all blocks and 'exploding' all proxy graphics. But DWG is not an option under Export. So I don't quite understand this option."
Block (*.dwg) is an Export option (in my seat of AutoCAD 2013), but I think it is essentially the same thing as WBlock (mentioned elsewhere), but I'm not sure what else this might refer to. Does the stuff you've read not specify the command or method to use?
