I was wondering if there was a way to convert a block that has been created without the allow exploding checked, to be changed so it can be exploded?
Solved by skintsubby. Go to Solution.
I found the answer on the manually link. Thanks
A manual method is to open the block with the Block Editor and change "Allow Exploding" in Properties to "Yes".
Then save the block with the changes (just in case you don't mind doing this one by one - maybe this information will help other users reading this topic).
Cheers,
Luciane
Luciane Conceição
Product Support Specialist
Autodesk, Inc
