AutoCAD Forum
Cache file without opening dwg
4 REPLIES 4
410 Views, 4 Replies
What I desire is just like we the publish command.  We can print dwgs without manually opening them.
Is there a way to produce an nwc in AutoCAD without manually opening the dwg.  Without appending or opening Navis to create a cache file.
In other words I want to NWCOUT a dwg without actually opening it.
I have:
2013 AutoCAD
2013 Manage
4 REPLIES 4
pendean
I have the exporter already. I want to take _NWCOUT out a step further.
I want it to work without technically opening the drawing.
I can add DWG directly to Navis. But I don't want to.
dgorsman
Why not use the auto-publish function thats included with Navisworks?
I didn't know of that feature other than publishing an NWD. I'll check it out and let you know.
Forma Design Contest
