Hi
scince I installed AutoCAD Map 3D 2014 my Laptop is starting very slow. I have a Thinkpad W530 with a 500GB SSD, so the start up should be really fast. But scince i have AutoCAD the laptop needs about 10 to 15 minutes bevore i can open any programm. (as the lenovo update center says i have the latest drivers)
My girlfriend who has a Dell Inspiron laptop (with a normal HDD) has the same problem scince she installed autoCAD.
If someone has any idea how to solve this problem i would be very glad.
At a guess, you've allowed 360 to start at WindowsStartup. Either uninstall 360 if you don't have a real need for it, or configure it to not start with Windows.
Second, look at Content Service. Either uninstall it (preferred option since it's not very useful) or usse the Service tool under computer management to set it to Manula start rathe than Automatic.
Let us know how those changes affect the startup time.
In the Windows Start menu, type MSCONFIG then go the Startup Tab and uncheck anything related to Autodesk, save and reboot.
neilyj (No connection with Autodesk other than using the products in the real world)
OK... now i unistalled all autodesk programs i had and the laptop is still not starting correctly. I installed autocad about 10 hours ago and this problem has never occured... i don't really know what to do if not even the uninstallation of the program could fix the start up problem.
@Anonymous wrote:OK... now i unistalled all autodesk programs i had and the laptop is still not starting correctly. I installed autocad about 10 hours ago and this problem has never occured... i don't really know what to do if not even the uninstallation of the program could fix the start up problem.
Try using Windows Restore and pick the most recent restore point before AutoCAD was installed >10 hours ago.
after the restoration the problem is fixed....but just not to use autocad is no solution for my work
but nevertheless thanks a lot
It may have just been a bad install. Since you know you can use Windows Restore, I'd use the Autodesk uninstall utility to make sure everything is cleaned up, then re-install AutoCAD. Other than that, about all you can do is submit a support request to Autodesk.
When you start the taskmanager, go to tab "Processes", add the column for "CPU time" (need to be added manually) you can see what process has used the 15 minutes. Don't forget also to turn on the option "show processes from all users"
That is the point to start then.
- alfred -
thats a good idea! I'll reinstall autocad and try that thing with the cpu time. I've also heared that kaspersky might make some trouble in combination with autocad. But we'll see^^
@neilyj666 wrote:
interesting about the suggestion that 360 is causing the problem, occasionally civil 3d seems to hang on the splash screen and using task manager to stop all Autodesk processes is the only way to allow it to start.
Is 360 fit for purpose?
I suppose it depends on hat your purpose is. IMHO 360 is a rather messy 'brand', with a lot of confusion about what it is, or even how many 'its' there really are. Of course, the same can be said about the 'cloud' buzzword... 360 as currently implemented on the desktop and in AutoCAD is not IMO ready for prime time. the configuration and end-user control of the background processes is not well thought out.
Synching setting to the cloude strikes me as a horrid waste of my cpy cycles and limited internet bandwidth. Once a user has set up his preferred settings, being able to take a snaposhot of that makes some sense -- but it would work FAR better if I could synch to a thumbdrive or local network share. Parking that information somewhere in the vagueness of the cloud is nonsensical and of no real benefit.
For collaboration and sharing project work -- 360 is less useful than the competition. Frankly speaking it's less effective than a 1990 era FTP site. Dropbox offers far more convenience, and SpiderOak offers security that is an order of magnitude greater.
Using a remote cloud service for rendering stills or animations is a very poor choice -- either local GPU processing, or LAN based grid computing would both work better, faster, more reliably, and more secure.
Some things do make sense to push to the cloud -- CFD for example, but they are all niche services, attractive primarily to people who only rarely perform those jobs, and can't justify the ROI of having that capability in-house.
That also means they are the people who have little real experience doing those jobs, so the results may look good, but are not backed by professional engineering judgement or validated by experience. There are substantial risks to the professional in using cloud computation. Liability beomes rather open-ended for him, with vendors taking no responsibility.
