welcome @forums.autodesk.com !
>> horizontal and veritcal lines display as different hues
I guess it's the resolution you've set for your graphics card that is different to the monitors "native" resolution.
Change the resolution to the maximum possible.
To verify if it's monitor/gc or if it's AutoCAD you can:
a) create a screenshot and save it as JPG
b) open that JPG with any graphic software like photoshop
c) rotate the image by 90° (so the lines that were vertical are now horizontal)
...now verify if "the error also rotated 90°" ... or not, if not it's "horizontal on monitor" (and not done by software).
HTH, - alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2024------------------------------------------------------------------------------------
(not an Autodesk consultant)
