I have a user with AutoCAD 2012, not Civil3D. Is there a way for this user to change the size of point labels in this program or is this a feature the program does not support and he needs to do it with point label styles in Civil3D?
Solved by Patchy. Go to Solution.
Hello from France
If your "classic" AutoCAD Points are on a different Layers or have a forced Color, you could easily select them !?
So with a Lisp/VLisp routine which draws Blocks on the selected Points, you will get differents "Styles of Points" ( = Different Blocks )
Please find attached this Lisp Routine P2B , that I use sometimes for this purpose ... Sorry I don't know the Author !
Loading with : APPLOAD
Run with : P2B
( Blocks must already exist in the current drawing )
Patrice BRAUD
