Hey all!
is it possible to insert an image with its path, advoiding the popup you get when using the standard ImageAttach method?
IE the command could be something like 'ImageAttach(\project\images\image1jpg)
Thanks!
Solved by Alfred.NESWADBA. Go to Solution.
start command _-IMAGE, then no popup will appear.
- alfred -
then run command _-ATTACH if you like that more.
>> is there a way to just enter the image path
Without an insertion point, a scaling, a rotation input AutoCAD will know what file you want to attach, but would not know where it should be positioned, how big it should be, and how it should be rotated.
[as long as it's not georeferenced, but in that case you would need Map3D and command _MAPIINSERT)
- alfred -
