AutoCAD Forum
PDF multi-sheet: objects printing in correct location on wrong page
2 REPLIES 2
264 Views, 2 Replies
I have a 15-layout file that I have set up to publish to multi-sheet DWF using DWG to PDF.pc3 plotter. At first glance, everything looks OK, but I found some lines and letters printed in the correct location on the page after the page that they should have printed (see attached sample file). Anybody have or hear of this issue?
2 REPLIES 2
rkmcswain
Can't say that I have ever seen that one.
Are you using the PUBLISH command, or publishing from Sheet Set Manager?
pendean
Are you usre that line isn't on a layer that is off in one viewport and on in another viewport?
A DWG file might be more useful than a final PDF.
”Boost
