AutoCAD 2007/2008/2009 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
repeat command line text
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
My second problem today, one of these days I guess.
Does anyone know how to change the feature that lets you repeat the text that was typed into your command line. In previous jobs I have been able to use the up and down arrows on the keyboard to scroll through text or commands that I have typed in (i.e the position and angle of a line, @254<35). On this PC that I am using when i try to get a repeat command text I only get a set of co-ordinates or no text at all.
Is there a parameter that has to be set to obtain the repeat text?
Re: repeat command line text
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Look up INPUTHISTORYMODE in the help files. Basically, it has to be an even number to have the old behavior, but be aware that using an even number also disables the ability to use the "down arrow" to access the menu of command options.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That did the trick. Thank you.
