Show only
Search instead for
Submitted byAnonymouson07-16-201307:50 AM
Status:
Implemented
Prompt before moving file to another folder
I run into this almost daily. Someone accidentally moves a file to another folder in the Vault. We should always be prompted if you really want to move the file or not.
In vault you can drag and drop a folder into another folder very easily. So easily that it happens a lot on accident. Unfortunately this command starts instantly and proceeds to happen whether you want it to or not. You are stuck waiting, sometimes for a long time, for the command to error out or complete, then you have to fix it. It would be tremendously helpful to have a "are you sure" dialog or at least a cancel button to help with this.
I really think that "files in folders" is a very old concept and should be banned from Vault.
Why not uses Vault as a database, it surely has one 😉
The user should not be bothered with the hassle of making sure the file is in the right folder, this is a file system issue, this should not be a problem in a database!
Instead make it possible to link the file to multiple projects/folders/labels/whatever (just like labels in gmail) and do not show the user where the file is actually stored.
And if you're one it, implement a classification system to make it easy as hell to find files and items.
Little hint Autodesk, take a look at your own end of life product "Productstream", incorporate a bit of that philosophy into Vault and reintroduce the perfect engineering workflow!
The product development team is considering the feedback of the community and have implemented some of this feedback in the development pipeline. You are encouraged to join the Autodesk Vault beta program to get a view into what’s being implemented. We appreciate your feedback.
This request has been implemented in Autodesk Vault 2016. Now the user get a prompt message (optionally) whether he want to move the files or folders to a different folder or not also a tooltip has been implemented to indicate the action happening on the file or folder whether it is a move or create link.
The message prompt can be controlled within the Options dialog "Configure Prompts".
