Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Copy-Design choose category-lifecycle-revision scheme
Consider this configuration:
Category Engineering
Revision Scheme: Prototype (default) / Production
Revision Scheme "Prototype"
00/01/02/03...
Revision Scheme "Production"
A/B/C/D...
1) Create a file 001.ipt
2) Check-in => revision = 00
3) Relesae the file
4) WIP the file=> revision = 01
5) Change revision scheme to Production => revision = A
6) Release the file
7) Perform a copy design in order to make a new prototype 001.ipt => 001_v2.ipt
8) The initial revision scheme of the original file is apply to the new file (default. 001_v2.ipt revision_scheme = Production / revision = A
9) Then change the unwanted revision scheme revision_scheme = Prototype / revision = 00
10) Release the file
11) WIP the file => revision = 01
12) change the revision scheme to Production revision = B
At this point it's not possible to start to A because this revision in already consumed.
If you give the right to choose cat/lfcyl/revscheme/rev during the prepare step of the Copy-design, this could be a great enhancement.
If you refund the copy-design tools in the future this could be something you must consider.
Thanks in advance.
2 Comments
YounesYammouri
olearya
The new version of Copy Design in Vault 2015 R2 enables users to reset or reuse the current category - this should then inherit the default revision scheme without consuming any revision scheme values.
