"Gama Z" stability coefficient according to NBR 6118
In the Stories table, you can find values describing story properties and the results associated with them.
Alpha cr X and alpha cr Y columns are available if Global mode elastic instability multipliers alpha cr along X, Y directions option is selected.
According to NBR 6118 brazilian code the data can be obtained from this table and analyzed in compatible situations like this example.
