Best way to model wood purlin, colar-beam and rafter
Hello.
I've got some issues with modeling roof. I would like to ask, what is the best way (most similar to reality) to model this type of detail in robot. The purlin and colar-beam aren't at the same height. Both are connected with the rafter. The colar-beam is also connected with purlin.
I tried with this solution, but I'm not sure about this. I created a connection between purlin and colar-beam with a bar with releases at both ends. But I'm not shure about this solution.
Could you recommend any solutions?
@Anonymous Hello, did you ever figure out how to model the 2D frame you attached to your post from last year? I am doing something similar and am not sure how to define the supports. If you have any updates I would be interested to know. Thank you!
