Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
(API) ROBOT / API / VBA - Panel cuts and table generation
8 REPLIES 8
Message 1 of 9
2110 Views, 8 Replies
I'm tying to make panelcuts on slabs. I saw that Rafal has already sent an example.
It's quite useful but i have some questions:
    - I also read on the forum that while generating a panel cut it's not possible to extract Bending moments or other sollicitations directly on Excel. Do i correctly understand?
    - Is it possible to open directly the diagram analysis of the cut in a window like it's possible with "geometry" or "loadings"?
I also tried to create tables to extract sollicitations on each point of the structure.
I've already managed to create a table wich gives Mxx/Myy/Mxy, but i'd like to have x, y, z, and others results like the shear effect by adding new columns.
You'll find below the code with the questions:
Sub table_creation()
Dim robot As New RobotApplication
Dim table_1 As RobotTable
Dim column_4 As IRobotTableDataType
Dim tableframe As IRobotTableFrame
Set table_1 = robot.Project.ViewMngr.CreateTable(I_TT_FE_RESULTS, I_TDT_MATERIAL)
table_1.AddColumn (column_1)
table_1.AddColumn (column_2)
table_1.AddColumn (column_3)
table_1.AddColumn (column_4)
column_1 = I_TDT_VALUES ' ___________              Wich command will return x values? y values? z values?
column_2 = I_TDT_DEFAULT  '________                   Wich command will return shear effect value?
column_3 = I_TDT_PANEL ' ___________                 Wich command will return z displacements values?
'____________________________________                 ? How can i get shear effect or other results ?
table_1.StoreSelection I_ST_FINITE_ELEMENT, "table_1"
table_1.Visible = True
'table_1.Printable.SaveToFile'                                         ? How to use this command for the .csv file creation ?
End Sub
Thanks for your help.
Regards.
8 REPLIES 8
Message 2 of 9
Rafal.Gaweda
First create such table (with these columns) manually in robot.
Use such \ similar script to find columns numbers:
Dim RT As RobotTable
Dim RTF As RobotTableFrame
Set RTF = Robapp.Project.ViewMngr.GetTable(1)
Set RT = RTF.Get(1)
For I = 1 To RT.ColCount
Cells(1, I) = RT.GetDataType(I)
Next I
 Then use these numbers in Table generation macro
Example:
Set RT = Robapp.Project.ViewMngr.CreateTable(I_TT_DYNAMIC, I_TDT_VALUES)
RT.AddColumn (257)
There is no such option.
Rafal Gaweda
Message 3 of 9
My comment to this part or Rafal's comment:
Maybe you can create txt file, which is "semicolon separated", and you can make code to search+replace those semicolons with commas.
With Rafal's help I've managed to extract table data to external file.
I've posted my code here:
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-get-load-combination-properties/m-p/4596...
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
Message 4 of 9
TXT = CSV
I do not think I is good idea or you have to change commas to dots firts - at least with my windows regional settings.
As far as I remember Decimal separator depends on windows system - be careful with changing
c#
read the file to string then
string.Replace(";",",")
Rafal Gaweda
Message 5 of 9
Yes, txt = csv  (should change extension also).
I agree, I forgot about that comma and dot stuff depending on system settings.
However, C# string.Split(';') and string.Replace() methods can make good work if one should implement them wisely.
Mirko Jurcevic
Message 6 of 9
Message 7 of 9
Yes, I've already check it out, and used logic from it for my app.
But now I want to close that table, look at my last question here:
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-get-load-combination-properties/td-p/458...
Mirko Jurcevic
Message 8 of 9
Checking it
Rafal Gaweda
Message 9 of 9
Rafal.Gaweda
in reply to: Rafal.Gaweda
