(API) Get local axis of finite elements
10 REPLIES 10
Message 1 of 11
2404 Views, 10 Replies
example.pngHi,
in the forum there is an example where you can get finite element results via API using an excell file and VBA.
Is there a possibility to get the orientation vectors for the local element system of the finite elements via API.
10 REPLIES 10
Message 2 of 11
Rafal.Gaweda
No.
Rafal Gaweda
Message 3 of 11
in reply to: Rafal.Gaweda
Hi Rafal, thanks for the answer. In my company we are trying to make an interface to Robot that would take nodes, finite element results for panels modelled in Robot and do reinforced concrete design in an home made application that has been used for the last 25 years, to design offshore gravity based structures. A similar interface exits for ANSYS. It seems that getting the orientation vectors for the local element system of the finite elements is not implemented in the API. If we have a simple panel let`s say a shear wall is there a possibility to get the orientation vectors of the panel local system? Thanks in advance, Alexander Ziotopoulos Multiconsult ASA www.multiconsult.no
Message 4 of 11
Rafal.Gaweda
But you will not get FE results in native FE LCS.
Results are always projected due to results presentation settings RobotFeResultsParams.SetDirX ; if not set - "Automatic" (= along panel X LCS) direction is considered.
If you want to consider "flat panel" + results presented in Automatic way you can take panel LCS
Rafal Gaweda
Message 5 of 11
Rafal.Gaweda
You may try - 1 FE = 1 panel and get LCS of this panel
I am attaching macro for creation panel for every single FE (make FE selection in Robot)
NOTE : huge number of panels in model reduces Robot performance, so be carefull using this approach on ALL (large number of) FEs in model
Rafal Gaweda
Message 6 of 11
Thanks Rafal,
you mention ''If you want to consider "flat panel" + results presented in Automatic way you can take panel LCS``.
Is there a method doing that via API? Is it possible to provide an example how to take out vectors for Local axis X,Y,Z for a flat panel. That would simplify
the whole process a lot.
Thanks in advance,
Multiconsult ASA
www.multiconsult.no
Message 7 of 11
Rafal.Gaweda
Public Sub CommandButton1_Click()
Dim RobApp As New RobotApplication
    Cells(5, 1) = "Project"
    Cells(5, 2) = RobApp.Project.Name
    Dim RSel As RobotSelection
    Set RSel = RobApp.Project.Structure.Selections.CreateFull(I_OT_PANEL)
    Dim PanelCol As RobotObjObjectCollection
    Set PanelCol = RobApp.Project.Structure.Objects.GetMany(RSel)
    Dim X As RobotGeoPoint3D, Y As RobotGeoPoint3D, Z As RobotGeoPoint3D
    Dim Obj As RobotObjObject
    Set X = RobApp.CmpntFactory.Create(I_CT_GEO_POINT_3D)
    Set Y = RobApp.CmpntFactory.Create(I_CT_GEO_POINT_3D)
    Set Z = RobApp.CmpntFactory.Create(I_CT_GEO_POINT_3D)
    For ii = 1 To PanelCol.Count
        Set Obj = PanelCol.Get(ii)
        Obj.Main.Attribs.GetLCS X, Y, Z
        Cells(12 + ii, 3) = Obj.Number
        Cells(12 + ii, 4) = "LCS X=" + Str(X.X) + ";" + Str(X.Y) + ";" + Str(X.Z)
        Cells(12 + ii, 5) = "LCS Y=" + Str(Y.X) + ";" + Str(Y.Y) + ";" + Str(Y.Z)
        Cells(12 + ii, 6) = "LCS Z=" + Str(Z.X) + ";" + Str(Z.Y) + ";" + Str(Z.Z)
    Next ii
End Sub
Rafal Gaweda
Message 8 of 11
Rafacascudo
Hi @Rafal.Gaweda ,
Does this work on Robot 2018 or 2019?
Rafael Medeiros
Message 9 of 11
Rafal.Gaweda
in reply to: Rafacascudo
Hi @Rafacascudo
Yes.
Rafal Gaweda
Message 10 of 11
Temo_Escudero
Hi, @Rafal.Gaweda,  I have a question, is there any way to apply surface loads directly over the finite element in the way the wind pressure analysis does, using the ROBOT API?, I mean, how can I generate such presure maps programatically. Greetings!
Message 11 of 11
Stephane.kapetanovic
