Showing results forĀ
ShowĀ Ā onlyĀ
Search instead forĀ
Did you mean:Ā
Thanks for your submission and votes on this idea! We are evaluating where this request falls into our roadmap and will provide an update when we have made a decision.
We've completed our review of this idea. After investigating the effort required to implement this request, we unable to add it to our roadmap at this time due to other priorities. However, we think this is a great idea so we will reconsider it as we made adjustments to our roadmap in the future. Thanks for the submission and keep voting!
Also, please make sloped Walls able to Host Rebars. The "wall by face" of today is not able to host rebars. Thats a problem for us structrual engineers.
After having to switch from Revit to ArchiCAD for modeling purposes one of the first things I've had to do using Revit is model a sloped and angled wall.
I did a bit of Youtube searching and couldn't believe how much of a farce this process is, considering it's just a setting in ArchiCAD which has been there for the last 4 releases roughly, i thought the process would be relatively similar.
Come on Revit catch up! The amount of time required to create these walls is just ridiculous either through the massing process or via creating Revit families.
We are in a great need for a slanted wall , just a generic slanted wall , its angle of slop to be under control , just a new wall type as the slanted columns,,,,,,
Without sloping walls (define angle of both faces) and without variable wall thickness, Revit is absolutely unusable for monuments restoration. Its fine to make complex wall using Mass Modelling. But make it behave like a regular wall (hosting openings, rebars and other elements, etc.).
I am already have created the sloped wall (slopping from one face) by using in place family , but I have a lot issues as updating the profile (for design modification) , inserting openings as windows and doors which act with a very weird behavior and could not be hosted all the time.
Rana Hamed Architect - Bim Specialist
Smart Village, Cairo-Alexandria Desert Road Street 26, Building 10 P.O. Box: 129, Giza 12577, Egypt Tel: +202 3531 8000 Fax: +202 3537 1223 dar.com
[cid:image001.png@01D26B25.EC7CF5A0] Please consider the environment before printing this document
And make it possible to use linear sweeps around corners with them.
Of course geometrical correct to get height points for each top and bottom point we need. This is possible when defining more than one path to sweep along.
Almost 2 years later is there any progress with implementing this feature?
Would be nice to finally add this feature in the Revit roadmap. We definitely understand it's a big deal for the developing team, but it's even bigger deal for Revit common users. Thanks!
This improvement would be very important for German Revit users. In the Revit Wishlist 2017 in Germany it ranked #13 out of 52 wishes. You can find more information on https://www.rug-dach.de/
@bjoern_teutriene Could you post a link to the wishlist itself (just curious)? The www.wishlist.rug-dach.de link just goes to the voting page (which is done) and I don't see anywhere to get the results.
