This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
"Hide Unchecked" for selected views/sheets to print
View/Sheet Set Needs a "Hide Unchecked" so you can see what sheets you actually have selected rather than having to sort through everything in the project. Other ideas have been suggested for printing from a schedule, which is fine if you only do sheets or a type of view. But if you're going to group things and sometimes print sheets and views together, then you need this.
3 Comments
We are pleased to say that this has been implemented in Revit 2023! Thank you for your contribution to improving Revit!
Help | Work with View/Sheet Sets for Export | Autodesk
 -The Factory
jjenkins2
The default for this feature is set to be on. Better would be to have the default unchecked so we don't accidently fail to print important sheets. Much better would be to give us the capability to have the default checked or unchecked per our needs.
I was informed by a member of the Autodesk expert network that the default cannot be changed as it is hard coded in the software. This is wrong, it should be an option for us to turn on when desired but normally be off.
viktar.kuzmichou
+1 to @jjenkins2.
Unchecking this button every time I print. Waste of time
