It is recommended that when importing survey coordinates into Revit, there should be an option to set the import based on survey points to avoid the imported points being too far away from the origin.
It is suggested that Revit should allow importing survey coordinates based on survey points, to avoid the imported points being too far away from the origin.
For example, if the survey point coordinates are X=1000, Y=1000, Z=1000, and the imported survey data point is X=2000, Y=2000, Z=2000. After importing, the point should be relative to the survey point, resulting in X=1000, Y=1000, Z=1000 relative to the project base point in Revit.
建议revit导入测量坐标是能设置根据测量点导入,避免导致导入的点离原点太远。
例如测量点坐标是X=1000,Y=1000,Z=1000;导入的测量测量数据点是X=2000,Y=2000,Z=2000。点导入到revit后能通过导入点是相对于测量点的。导入后相对于项目基点就成了X=1000,Y=1000,Z=1000。
Forma Design Contest
Technology Administrators
