Able to still select elements when Visibility/Graphic Overrides Window Open
It is frustrating when trying to control the visibility of objects when you constantly have to go open the VG window turn on/off the necessary sub category then close window and go perform required actions on your model only to find you need to turn something else on/off to continue. Recommend that selection of objects within the drawing area should still be selectable even if the VGO window is open.
2 Comments
wr.marshall
Zin_Phi_
If the V/G window is open, it is no longer possible to continue working. It would be nice if the V/G window could be handled in the same way as the properties window. It is often quite time consuming to enter the V/G window, switch to the filter views, set filters and back again
If the V/G window can remain open and the settings are applied immediately (without having to click on Apply) you save a lot of time
Autodesk Customer Advisory Groups
