Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Workshared Element User History
6 REPLIES 6
McCulloughRT
1172 Views, 6 Replies
Hello friends,
If I turn on one of the worksharing display modes, and then hover my mouse over any element, I get a popup advising me of who that element was originally created by and who last updated it on the central model, as shown below:
I've searched through the api help file, and online, but cannot find any description of where this information is stored or if it is even accessible through the API. Does anyone know how I might be able to programatically access these feilds?
6 REPLIES 6
jeremytammik
in reply to: McCulloughRT
In general, I do not believe you will ever be able to see anything whatsoever in Dynamo that is not API accessible.
Furthermore, you can look at the Dynamo source code to determine how the data is retrieved, and where from.
I have not looked myself, and I am not sure whether this is the right path, but here goes:
Each Revit element belongs to one and only one workset.
Its workset can be determined by the Element.WorksetId property.
The workset is derived from WorksetPreview, which offers the Owner property.
I hope this helps.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
McCulloughRT
in reply to: jeremytammik
Thanks for the reply Jeremy, but I'm a bit confused, as I'm not using Dynamo. If it has some functionality that can retrieve this data for me, then I'm not opposed to using it, but I'd prefer to stick to coded API.
As for WorksetPreview, it appears this will give me the owner of the entire workset (if it has been checked out), but what I'm looking for is the history that Revit appears to store somewhere of which user last updated a specific element with a synchronization to the central model.
McCulloughRT
Anybody have any ideas? I'm starting to think the API just doesn't provide access to this, but if it does it could be very useful for tracking work and delegating tasks in our firm!
jeremytammik
I'm asking the development team...
Jeremy Tammik
The Building Coder
jeremytammik
I received an answer, and the access is there:
http://thebuildingcoder.typepad.com/blog/2015/11/worksharingutils.html
Hooray!
Please let us know how it works out for you, preferably with a snippet of sample code.
Thank you!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
McCulloughRT
Fantastic! Thanks so much Jeremy!
I'm working hard on a project deadline on the Architecture side of things right now, but will dive into this after the weekend. I'll be sure and post back with a code example!
Rail Community
