So running into a bind with wanting to add company prefix to all of the shared parameters on our FAB sheets, I tried a lil experiment. I edited the Shared Parameter .TXT file and renamed it there.
Obviously all of my labels seperated, but so far I see it seems to work. The Parameter names seem crosswired though, areas such as Phase, were prefixed with JHK_.
You can clearly see the Shared Parmeter name change took here; but...
When I attempt to Edit the existing label, the name pulls in the previous version.
JHK_FAB_Line No. Worked with no issue at all, as you can see the name in the list of labels (Was previously applied.)
Anyone ever try to do this with any success? Or am I simply playing with GUID fire? (Seems the GUID's wouldn't change, since they're IN the text file as well, but then, why are the "Name" fields not fully pulling thru? (Is this a crosswired GUID running in the background at this point?)
(Sometimes you severly have to break things to understand them and reverse engineer the issues!)
