ObjectARX
Proxy entity geometry?
4 REPLIES 4
824 Views, 4 Replies
I need to get the geometric data of the ACAD_PROXY_ENTITY for exporting purposes (of course without the presence of the proxy parent application). Is there any ObjectARX or ads api to get such information?
4 REPLIES 4
In ARX you can get an AcDbProxyEntity
There you have the member getGeomExtens, and you can explode it (if it is
allowed)
getGeomExtents:
This function fills in extents with the approximate extents of the proxy. If
the proxy has graphics saved, then these are used to calculate the extents.
If only a bounding box is available, then the extents are those of the
bounding box.
explode:
This function creates copies of all the graphics metafile primitives stored
in the proxy and append the pointers to these new entity objects to the
entitySet array.
Returns Acad::eOk if successful, otherwise returns
Acad::eCannotExplodeEntity.
wrote in message news:4819995@discussion.autodesk.com...
It is possible, see the solution in:
[Arx path]\samples\database\ARXDBG\Inc\ArxDbgWorldDraw.h
[Arx path]\samples\database\ARXDBG\Tests\ArxDbgWorldDraw.cpp
[Arx path]\samples\database\ARXDBG\Inc\ArxDbgViewportDraw.h
[Arx path]\samples\database\ARXDBG\Tests\ArxDbgViewportDraw.cpp
Hokus
thanks a lot!
I hope exploding you mentioned will not change the object (drawing) itself.
Thank you
Technology Administrators
