Inventor 2022 OnFileSaveAsDialog Event
11 REPLIES 11
Message 1 of 12
julian_sol
1054 Views, 11 Replies
Since I've updated to Inventor 2022 (and it's API) my OnFileSaveAsDialog Event does not trigger anymore on saving a new file. Instead I get this new save dialog:
Did the OnFileSaveAsDialog event change? How can I capture this command in the new version?
Labels (2)
11 REPLIES 11
Message 2 of 12
Ralf_Krieg
in reply to: julian_sol
Hello
Afaik there's no change on this event.
How did you catch this event? VBA, iLogic, VB.Net Addin?
The Dialog looks like Vault? Have you used it also before 2022?
R. Krieg
RKW Solutions GmbH
www.rkw-solutions.com
Message 3 of 12
julian_sol
in reply to: Ralf_Krieg
Thanks for your response. It is indeed the Vault Plugin that is causing this dialog to pop up.
I'm catching the event in a C# .NET plugin as below:
        private Inventor.Application InventorApplication { get; set; }
        private FileUIEvents FileUiEvents { get; set; }
        public void Activate(Inventor.ApplicationAddInSite addInSiteObject, bool firstTime)
            // Initialize AddIn members.
            InventorApplication = addInSiteObject.Application;
            FileUiEvents = InventorApplication.FileUIEvents;
            FileUiEvents.OnFileSaveAsDialog += FileUiEventsOnOnFileSaveAsDialog;
        private void FileUiEventsOnOnFileSaveAsDialog(ref string[] filetypes, bool savecopyas, int parenthwnd, out string filename, NameValueMap context, out HandlingCodeEnum handlingcode)
           // NORMALLY I WOULD OPEN A CUSTOM WINDOW HERE
            throw new NotImplementedException();
If I logout of Vault, the code works and the event is triggered. If I'm logged in I get the Vault dialog.
Would you know how to turn this off or skip this? Thanks!
Message 4 of 12
Ralf_Krieg
Hello
Afaik, if two or more Addins listen to the same event, there's no possibility to define the order the Addins code run. I'm not familar with Vault. The Basic client offers no API. If it's a higher version, maybe one of the following ideas can help:
- Check if it's possible to configure Vault plugin to not listen on this event.
- Check if there's an event in Vault API open the dialog (CreateNewFileDialog) and create a handler to suppress the Vault dialog and display your own.
R. Krieg
RKW Solutions GmbH
Message 5 of 12
Vault API does not support that kind of events!
Arthur Knoors
Autodesk Affiliations:
Message 6 of 12
julian_sol
I found what was causing the unwanted dialog to show up. It's the extra Vault Datastandard Addin. It uses the same save command ID and this apparently overwrites the standard Inventor save method.
Message 7 of 12
Ralf_Krieg
Hello
Maybe an interesting article
https://knowledge.autodesk.com/support/vault-products/learn-explore/caas/CloudHelp/cloudhelp/2020/EN...
R. Krieg
RKW Solutions GmbH
Message 8 of 12
julian_sol
Thank you, that's definitely useful. I don't think we'll need the Datastandard Addin at all, but it's good to know something exists to bypass this!
Message 9 of 12
wood.isbell
This conversation seemed relevant to an issue I am having, but I am not running the Data Standard add-in and my handler is not being called with or without being logged into Vault. I am using the same handling method, and it worked in 2020, but not in 2022.
Separately, I confirmed that it is not another add-in by disabling everything outside of my add-in; no dice.
Message 10 of 12
wood.isbell
Forget that. I forgot to set the new DLL as Embed Interop Types = False.
Message 11 of 12
bor_ani
in reply to: wood.isbell
Thanks man, you saved me.
Message 12 of 12
amriSWAA3
This fixed my issue. Thanks @wood.isbell
