Did anyone try to demote a frame member through API?
I tried with command manager:
ThisApplication.SilentOperation = True Dim oCM As CommandManager Set oCM = ThisApplication.CommandManager ' Prepopulate the file name of new component in ' the 'Create Component' dialog oCM.PostPrivateEvent kFileNameEvent, "C:\temp\test\demoted.iam" Dim oControlDef As ControlDefinition Set oControlDef = oCM.ControlDefinitions("AssemblyDemoteCmd") ' Execute the demote command oControlDef.Execute ThisApplication.SilentOperation = False
I also tried with this example:
Public Sub Demote() ' Get the active assembly document Dim oDoc As AssemblyDocument Set oDoc = ThisApplication.ActiveDocument Dim oDef As AssemblyComponentDefinition Set oDef = oDoc.ComponentDefinition ' Get the occurrence to be demoted Dim oOcc As ComponentOccurrence Set oOcc = oDef.Occurrences.Item(1) ' Create a new sub-assembly to demote the occurrence into Dim oNewSubAssy As AssemblyDocument Set oNewSubAssy = ThisApplication.Documents.Add(kAssemblyDocumentObject, , False) Dim oMat As Matrix Set oMat = ThisApplication.TransientGeometry.CreateMatrix ' Create an instance of the new sub-assembly Dim oSubAssyOcc As ComponentOccurrence Set oSubAssyOcc = oDef.Occurrences.AddByComponentDefinition(oNewSubAssy.ComponentDefinition, oMat) ' Get the model browser Dim oPane As BrowserPane Set oPane = oDoc.BrowserPanes.Item("Model") ' Get the browser node that corresponds to the new sub-assembly occurrence Dim oSubAssyNode As BrowserNode Set oSubAssyNode = oPane.GetBrowserNodeFromObject(oSubAssyOcc) ' Get the last visible child node under the sub-assembly occurrence Dim oTargetNode As BrowserNode Dim i As Long For i = oSubAssyNode.BrowserNodes.Count To 1 Step -1 If oSubAssyNode.BrowserNodes.Item(i).Visible Then Set oTargetNode = oSubAssyNode.BrowserNodes.Item(i) Exit For End If Next ' Get the browser node that corresponds to the occurrence to be demoted Dim oSourceNode As BrowserNode Set oSourceNode = oPane.GetBrowserNodeFromObject(oOcc) ' Demote the occurrence Call oPane.Reorder(oTargetNode, False, oSourceNode) End Sub
But no luck, it won't demote.
Same codes work in a standard assembly.
Any advice?
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Can you please post the entire code?
Here is mine:
Sub DemoteWithCommand() Dim oDoc As AssemblyDocument Set oDoc = ThisApplication.ActiveDocument Dim oDef As AssemblyComponentDefinition Set oDef = oDoc.ComponentDefinition 'Set a reference to the first occurrence Dim oOcc As ComponentOccurrence Set oOcc = oDef.Occurrences.Item(3) Dim oItemToMove As Object Set oItemToMove = oOcc 'Clear select set oDoc.SelectSet.Clear 'Add the occurrence to demote to the select set oDoc.SelectSet.Select oItemToMove ThisApplication.SilentOperation = True Dim oCM As CommandManager Set oCM = ThisApplication.CommandManager ' Prepopulate the file name of new component in ' the 'Create Component' dialog oCM.PostPrivateEvent kFileNameEvent, "C:\Users\asi\Desktop\1000-Desktop\Inventor\frame test\Assembly3.iam" Dim oControlDef As ControlDefinition Set oControlDef = oCM.ControlDefinitions("AssemblyDemoteCmd") ' Execute the demote command oControlDef.Execute ThisApplication.SilentOperation = False End Sub
It seems like oControlDef.Execute doesn't run, because occurrence item(3) stays selected after I run the macro.
Arthur Knoors
Arthur Knoors
Hm... The dialog box appeared now even though the SilentOperation is set to True.
That's really strange..
Can you please post the entire code? I just can't figure out why it's not working for me...
Hey Arthur,
Would you be able to help on this subject? 🙂
I still can't demote a frame member with oCM.ControlDefinitions("AFG_CMD_Demote")...
