Demote Frame Member through API
7 REPLIES 7
Message 1 of 8
fakeru
727 Views, 7 Replies
Did anyone try to demote a frame member through API?
I tried with command manager:
ThisApplication.SilentOperation = True
Dim oCM As CommandManager
Set oCM = ThisApplication.CommandManager
' Prepopulate the file name of new component in
' the 'Create Component' dialog
oCM.PostPrivateEvent kFileNameEvent, "C:\temp\test\demoted.iam"
Dim oControlDef As ControlDefinition
Set oControlDef = oCM.ControlDefinitions("AssemblyDemoteCmd")
' Execute the demote command
oControlDef.Execute
ThisApplication.SilentOperation = False
I also tried with this example:
Public Sub Demote()
    ' Get the active assembly document
    Dim oDoc As AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oDef As AssemblyComponentDefinition
    Set oDef = oDoc.ComponentDefinition
    ' Get the occurrence to be demoted
    Dim oOcc As ComponentOccurrence
    Set oOcc = oDef.Occurrences.Item(1)
    ' Create a new sub-assembly to demote the occurrence into
    Dim oNewSubAssy As AssemblyDocument
    Set oNewSubAssy = ThisApplication.Documents.Add(kAssemblyDocumentObject, , False)
    Dim oMat As Matrix
    Set oMat = ThisApplication.TransientGeometry.CreateMatrix
    ' Create an instance of the new sub-assembly
    Dim oSubAssyOcc As ComponentOccurrence
    Set oSubAssyOcc = oDef.Occurrences.AddByComponentDefinition(oNewSubAssy.ComponentDefinition, oMat)
    ' Get the model browser
    Dim oPane As BrowserPane
    Set oPane = oDoc.BrowserPanes.Item("Model")
    ' Get the browser node that corresponds to the new sub-assembly occurrence
    Dim oSubAssyNode As BrowserNode
    Set oSubAssyNode = oPane.GetBrowserNodeFromObject(oSubAssyOcc)
    ' Get the last visible child node under the sub-assembly occurrence
    Dim oTargetNode As BrowserNode
    Dim i As Long
    For i = oSubAssyNode.BrowserNodes.Count To 1 Step -1
        If oSubAssyNode.BrowserNodes.Item(i).Visible Then
            Set oTargetNode = oSubAssyNode.BrowserNodes.Item(i)
            Exit For
        End If
    Next
    ' Get the browser node that corresponds to the occurrence to be demoted
    Dim oSourceNode As BrowserNode
    Set oSourceNode = oPane.GetBrowserNodeFromObject(oOcc)
    ' Demote the occurrence
    Call oPane.Reorder(oTargetNode, False, oSourceNode)
End Sub
But no luck, it won't demote.
Same codes work in a standard assembly.
Any advice?
Autodesk Inventor 2015 Certified Professional
7 REPLIES 7
Message 2 of 8
bradeneuropeArthur
in reply to: fakeru
for me the first code works fine...................................
Arthur Knoors
Autodesk Affiliations:
Message 3 of 8
fakeru
in reply to: bradeneuropeArthur
Can you please post the entire code?
Here is mine:
Sub DemoteWithCommand()
'Set a reference to the first occurrence
Set oOcc = oDef.Occurrences.Item(3)
Dim oItemToMove As Object
    Set oItemToMove = oOcc
'Clear select set
oDoc.SelectSet.Clear
'Add the occurrence to demote to the select set
oDoc.SelectSet.Select oItemToMove
oCM.PostPrivateEvent kFileNameEvent, "C:\Users\asi\Desktop\1000-Desktop\Inventor\frame test\Assembly3.iam"
oControlDef.Execute
End Sub
It seems like oControlDef.Execute doesn't run, because occurrence item(3) stays selected after I run the macro.
Message 4 of 8
bradeneuropeArthur
in reply to: fakeru
for me that code works fine!
Arthur Knoors
Message 5 of 8
use this instead:
Set oControlDef = oCM.ControlDefinitions("AFG_CMD_Demote")
Arthur Knoors
Message 6 of 8
fakeru
Hm... The dialog box appeared now even though the SilentOperation is set to True.
That's really strange..
Message 7 of 8
fakeru
Can you please post the entire code? I just can't figure out why it's not working for me...
Message 8 of 8
fakeru
Hey Arthur,
Would you be able to help on this subject? 🙂
I still can't demote a frame member with oCM.ControlDefinitions("AFG_CMD_Demote")...
