you can do this with a reader,
I do that for a table in drawing, see the code
the code run in the 2 directions
I take the data from the SQL
or I write in the SQL
It's in french, if you don't understand, I'll translate
SyntaxEditor Code Snippet
AddReference "System.Data"
AddReference "System.Core"
AddReference "System.Xml"
'Imports System.Data.OleDb
Imports System.Data
Imports System.Xml
Imports System.Data.SqlClient
'++++++++++++++++EXTRACTION N° DE PROJET++++++++++++++
Dim NomFi As String
Dim NumProj As String
Dim DecFi As Object
NomFi = ThisDoc.FileName(False)
DecFi = Split(NomFi, "-")
NumProj = DecFi(0)
MessageBox.Show(NumProj, "Title")
'+++++++++++++++++++++LIEN SQL+++++++++++++++++++++
Dim myConn As SqlConnection
Dim myCmd As SqlCommand
Dim myReader As SqlDataReader
Dim results As String
Dim Req As String
Dim ReqInsert As String
'Definition de la connexion
myConn = New SqlConnection("Data Source = SRV-SQL ;Initial Catalog = SqlBase1 ;User Id = sa ;Password = 123 ; ")
'requete d'interrogation
Req = "SELECT Codelancement,DateCreationLct FROM HART_PLAN_LCT LIMIT1 WHERE DesignationLct4='" + NumProj + "' ORDER BY DateCreationLct DESC"
myCmd = myConn.CreateCommand
myCmd.CommandText = Req
'Ouverture de la connexion
myConn.Open()
myReader = myCmd.ExecuteReader()
'Controle de la presence de donnees dans le reader
'If myReader.HasRows = False Then
'MessageBox.Show("faux", "Title")
'Else
'Inscrire le resultat de la requete dans une chaine de caracteres
'Do While
'myReader.Read()
'results = myReader.GetString(0)
' Loop
'Affichage du resultat.
'MsgBox(results)
'++++++++++++++Definition des points d'insertion++++++++++++++++
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = oDrawDoc.Sheets.Item(1)
'Dim oTG As TransientGeometry
'oSheet.Size=9993 A0
'oSheet.Size=9994 A1
'oSheet.Size=9995 A2
'oSheet.Size=9996 A3
'oSheet.Size=9997 A4
'oSheet.Orientation=10243 portrait
'oSheet.Orientation=10242 paysage
'A0portrait
If oSheet.Size = 9993 And oSheet.Orientation = 10243 Then
Xpt3 = oSheet.Width - 9.84
Xpt4 = oSheet.Height - (oSheet.Height - 6.3045)
'A0paysage
ElseIf oSheet.Size = 9993 And oSheet.Orientation = 10242 Then
'A1portrait
ElseIf oSheet.Size = 9994 And oSheet.Orientation = 10243 Then
'A1paysage
ElseIf oSheet.Size = 9994 And oSheet.Orientation = 10242 Then
'A2portrait
ElseIf oSheet.Size = 9995 And oSheet.Orientation = 10243 Then
Xpt3 = oSheet.Width - 8.84
Xpt4 = oSheet.Height - (oSheet.Height - 5.3045)
'A2paysage
ElseIf oSheet.Size = 9995 And oSheet.Orientation = 10242 Then
'A3portrait
ElseIf oSheet.Size = 9996 And oSheet.Orientation = 10243 Then
'A3paysage
ElseIf oSheet.Size = 9996 And oSheet.Orientation = 10242 Then
'A4portrait
ElseIf oSheet.Size = 9997 And oSheet.Orientation = 10243 Then
'A4paysage
ElseIf oSheet.Size = 9997 And oSheet.Orientation = 10242 Then
End If
'++++++++++Definition et insertion de la table de revision+++++++++++++
If oDrawDoc.ActiveSheet.RevisionTables.Count = 0
'Creation du point d'insertion
Dim oPoint2 As Point2d
oPoint2 = ThisApplication.TransientGeometry.CreatePoint2d(Xpt3, Xpt4)
'Definition table de revision
Dim oRTBs As RevisionTables
oRTBs = oDrawDoc.ActiveSheet.RevisionTables
'Insertion table de revision
Dim oRTB As RevisionTable
oRTB = oRTBs.Add(oPoint2)
End If
'+++++++++++++Ecriture dans la table de revision+++++++++++++++++
Dim oRevTable As RevisionTable = oDrawDoc.ActiveSheet.RevisionTables.Item(1)
' Choix de la derniere rangee
Dim oRow As RevisionTableRow
oRow = oRevTable.RevisionTableRows.Item(oRevTable.RevisionTableRows.Count)
Dim oCell As RevisionTableCell
myReader.Close()
' Verification range active dans tableau
If oRow.IsActiveRow Then
' Go through all columns in that row
For i = 1 To oRevTable.RevisionTableColumns.Count
oCell = oRow.Item(i)
If i = 2 '2nd colonne de la table de revision
oCell.Text = InputBox("Entrer le N° d'OF", "Historique et OF", "XX-XXXXX")
'++++++++++++++++++INSERTION N° DE PLAN DANS BASE SQL++++++++++++++++++++++++++++
Question = MessageBox.Show("VOULEZ VOUS AFFECTER LE N° DE PLAN A L'OF DANS LA BASE SILOG (Ecrire le N° saisi dans la base de données)", "PLAN NON AFFECTE", MessageBoxButtons.YesNo, MessageBoxIcon.Question)
If Question = vbYes Then
ReqInsert = "UPDATE LCTE Set DesignationLct4 ='" + NumProj + "' Where CodeLancement ='" + oCell.Text + "'"
Dim myCmd2 As New SqlCommand(ReqInsert, myConn)
myCmd2.ExecuteNonQuery()
End If
ElseIf i = 3 '3eme colonne de la table de revision
oCell.Text = InputBox("Quantité à Produire", "Historique et OF", "1")
ElseIf i = 4 '4eme colonne de la table de revision
oCell.Text = InputBox("Modification", "Historique et OF", "")
End If
oCell.Text = oCell.Text 'defini la cellule en statique
Next
End If
Else
myReader.Read()
' Make sure we have the active row
oCell.Text = InputBox("Entrer le N° d'OF", "Historique et OF", results)
End If
Next
End If
End If
'fermeture du reader et de la connexion
myReader.Close()
myConn.Close()
