Rock anchored bolt
joseiochoam
Rock anchored bolt
joseiochoam
Dear John,
I would like to know if it is possible to simulate the anchoring of a bolt nailed into a rock. The rock would be at the bottom of the sea to anchor a 10 m boat, and since the bolt has been torn off after a storm (it has no deformations), the idea is to determine the maximum force that the assembly can support without the bolt sliding out (they forgot to put resin). In the hole drilled into the rock, I understand that we must of course apply friction, but I don't know if it is possible.
What type of analysis would be appropriate? In the drilled hole (bolt diameter is 16.1 mm) should there be some clearance between the rock and the bolt?
Please find below some images.
Many thanks!
John_Holtz
Autodesk Support
Autodesk Support
Hi @joseiochoam
I suggest that you forget about trying an analysis with friction because:
  • the initial conditions are unlikely to be known with any accuracy. What size is the hole (to the nearest 0.1 mm)? How straight is the hole? How straight is the bolt? What is holding the bolt in place if there was no resin? A minor change in any of those factors will change the answer. Thus, you need to do N analyses to get a range of answers.
  • Perhaps you know how much force was required to put the bolt into the hole. Would the force to remove the bolt be the same?
  • You can include friction in an analysis, but it makes the analysis 3 to 10 times more difficult. The way to get the answer with friction is to do the analysis to calculate only the normal contact force. Based on the normal force, you calculate the friction force by hand (= friction coefficient*normal force). N simple analyses (for all the variables) done in minutes instead of N complex analyses, each of which takes hours to complete.
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
joseiochoam
Dear John, as always, many thaks for your great help, and it is clear.
Regarding data 316L bolt is 16,1 mm diameter, bolt has 260 mm length, and drill hole in rock is 150 mm. For rock we consider calcita material.
As you said, I will calculate manually normal force
Best regards
Jose
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
