& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
Dear community,
could you give me a hint where to find an example to develop a sidebar for Inventor?
I already developed this one, which I would like to port to Inventor and would like to continue to develop together with you as a community project opensource'd. It might be that I'm using the wrong term ("sidebar"), therefore here a screenshot of what I have.
Thanks!
- Thomas
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
While browsing through the internet, it seems to be it. However, I only can find anything specific to begin to develop such a browser control.
Do you or someone else know, where to find a template or a good howto?
Many thanks so far!
Try this way:
Sub DockableWindow() Dim oUserInterfaceMgr As UserInterfaceManager Set oUserInterfaceMgr = ThisApplication.UserInterfaceManager ' Create a new dockable window Dim oWindow As DockableWindow Set oWindow = oUserInterfaceMgr.DockableWindows.Add("SampleClientId", "TestWindowInternalName", "Test Window") ' Get the hwnd of the dialog to be added as a child ' CHANGE THIS VALUE! Dim hwnd As Long hwnd = 4851096 ' Add the dialog as a child to the dockable window Call oWindow.AddChild(hwnd) ' Don't allow docking to top and bottom oWindow.DisabledDockingStates = kDockTop + kDockBottom ' Make the window visible oWindow.Visible = True End Sub
Or look in the help file of inventor programming help file:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Thank you for the hint. I will take a look at it as soon as I have time.
When further questions occur, I will open new threads here in the forum.
Thanks!
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
