Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Visibility of parts
Visibility of parts
Make it possible to see for example how deep a screw is screwed in into another part after select it. At the moment you just see the already visible area of the screw. the unvisible area is  hidden. See attached a screenshot.
Also attached a screenshot from a CAD system that already implements this function.
5 Comments
doug.johnston
This would be a great addition.
I currently just "edit" the fastener inside the assembly, which highlights the screw and "ghosts" the assembly model.
While not the best solution, it does work to see how far into the hole the screw is.
It would also be great to have this in the part area. If I select for example a whole with thread in the browser list, i want to see how depp is the thread and the tap hole.
It is nearly the same. I want that the part becomes really shown. Not just the lines. The whole part should be colored like in the example I attached.
Just make your part transparent in the assembly I do this all the time. Right click on the part make transparent.
