Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Split Feature Distance
Right now the split feature reads the "Tool" as a plane (meaning there is no start or beginning of the "Tool"). This can cause issues if I am just wanting to split one portion of the solid body. There should be an option or way to say you want to treat the "Tool" as a plane (no start or end) or a line (defined start and end).
For example, if I have a pipe that I did a sweep to get the overall path. Then I draw a line where I want to split the pipe (at the miter location). Once I select that line as the "Tool" it actually reads it as a plane and splits everything that it would intersect.
3 Comments
Thicken (new body mode) + Combine (cut mode & save old body option).
No sketches; no workplanes; no split; no stress.
It works.
dieter
Ich mache z.B. eine Extrusion als Fläche. Dann kann ich nur einen Teil des Rohres trennen.
peter.roman
My workaround is to create a flat surface body with the limited extents required (same as dieter's comment). I can also extend this to non-flat surface bodies to do more complicated splits.
