Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Select Features in derived part
It would be great if we could select which features we want to derive, when we use derived part option.
12 Comments
We have sometimes have situations where two parts are almost mirror images of each other, but not quite. One part will have a hole or two that its counterpart doesn't. This presents us with a choice:
1) Make a mirror image derived part and then add or remove features as needed.
2) Forget the derived part and model both parts from scratch.
I'd like to see the ability to generate a mirror image part that wasn't a dumb solid and had all the sketches, features, you name it, of the original part, but in mirror image. I would not expect the mirror-image part subsequently to update with changes in the original part. If I did change the original part and wanted the mirror image part to reflect the changes, I'd derive the mirror image part again if that seemed the most straightforward approach.
A couple of years ago I ran this idea past someone from our reseller at user group meeting, and he said I wasn't the first person to request it.
Tags (1)
coreyparks
When inside the part file you want to mirror fire up the mirror command nomally used for mirroring features.  If you look at the 2 buttons on the left one says mirror individual features and the other says to mirror solid.  If you mirror the entire solid you are allowed to choose if you would like to delete the original or not.  This keeps the entire model tree identical to the base part with any new different features being added after the mirror function.  Is this what your looking for?
Yes, that did the trick, thanks!
dusan.naus.trz
solid edge ST9 2016 can better mirror the components, mirror sketch
https://www.youtube.com/watch?v=Ce2NgnsM5ec
also maybe in Inventor 2018 ?
inv.ideareview
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly - it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Inventor product team (Inv.idea review)
inv.ideareview
Status changed to: Archived
dusan.naus.trz
When will it be implemented? The colleague wanted to vote and it was not possible.
jacek_stirba
When will it function? Can not vote?
edwardcalderon
It would be very useful for me. I need to document manufacturing sequences for parts, for example documenting separate turning and milling.
Thumbs up
This is really necessary & basic functionality that should be available.  It's obvious that you might have a derived part, such as a mirrored component, that has the same basic form but not all the same features (such as holes, milled features, etc.).  The way this is set up is tedious.  If I have to alter the features of the base component I should be able to do so & control how it affects the derived component.
Yijiang.Cai
Many thanks for posting the idea, and tracked as [INVGEN-81541]
