This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Rename Browser Nodes (using part numbers)
Good morning,
using the "Rename Browser Nodes (using part numbers)" command Inventor does not start the procedure because the assembly contains suppressed sub-parts within it.
Is it possible to limit the rename function to the first level only? Otherwise, make it skip suppressed items
This feature along with model states would make a difference
Thank you
Buongiorno,
usando il comando "Rename Browser Nodes (using part numbers)" Inventor non avvia la procedura poichè l'assieme contine al suo interno sotto-particolari soppressi.
E' possibile limitare la funziona rinomina al solo primo livello? Altrimenti fare in modo che salti gli elementi soppressi
Questa funzione insieme agli stati modello farebbe la differenza
Grazie
