The "Copy properties" option, which is available when copying tolerances and dimension styles from one dimension to another on 2D drawings, should also be implemented for hatching. The automatically generated hatch is often not ideal, and this feature would significantly speed up its refinement. It would be sufficient to allow copying of the "scale," "angle," and "pattern" properties.
