This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
break center lines when crossing dimensions
It would be awesome if the centerlines were automatically breaked when they cross dimensions. that is possible to do on autocad.
undefined
12 Comments
lesmfunk
Do dimensions need to be centered?
I see your point for other situations, but not the one in the graphic.
dan_szymanski
Status changed to: Accepted
Accepted idea [430]. Thanks!
stuartmp
Hi Dan,
Its great that this was accepted, is there a way to find out in what version it will be implimented?
I really hope inventor can do that, but now I just use sketch to cut center lines.
dan_szymanski
Idea added to backlog for future consideration [430]. Thanks!
AttilaFarkas
Guys,
Inventor doesn't split the centerline at the dimension and this is a very frustrating behaviour for a long time.
I think it should be a basic function in the drawing.
Attila
dusan.naus.trz
A possible solution for a new feature? Color dimension background. Dimension to the forefront. Axes on background.
Using function?
https://forums.autodesk.com/t5/inventor-ideas/new-function-backround-fill-in-dimension/idi-p/8253232
grzegorz.podolewski
I agree with dusan, interesting color background as Autocad. Great Idea. When will the realization?
Both Center- and Section lines don't break for Dimensions or Balloons while Dimension lines do break for Balloons. I hope this can be implemented in the future. I have issues with this almost on a daily base when working in drawing environment.
dan_szymanski
dan_szymanski
This idea has been implemented within Autodesk Inventor 2022. Special thanks to everyone who cast a vote for it.
How about making a tab in the tool bar when creating drawings to easily change dimension fonts and sizes.  The biggest complaint I have from suppliers is the font size is too small and changing it is not always successful and is much more complicated than it needs to be.
