The "Match properties" needs voting on the idea station. That way you could use the "Match Properties" to adjust Connection distances to all fittings.
Give us a vote if you feel the need:
http://forums.autodesk.com/t5/inventor-ideastation/tube-and-pipe-overhaul/idi-p/5518269
look for item 39 in the comments
39 – Give us a “Match Properties” function like the one in the drawing for “Copy Dimension Properties”. On the same principle if you right click when the command is active you get a “Settings” menu where you can choose what to copy: Material, Appearance, Orientation, Diameter, Connection (distances). The Orientation (rotation) is going to be the hardest but I suggest using connection 1 (they all have at least 1 connection) as the rotation axis and Z axis as direction.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
