Inventor Forum
Inventor 2012 - "Problems encountred while executing frame insert command"
8 REPLIES 8
Message 1 of 9
709 Views, 8 Replies
Hi there:
I'm having a issue with Autodesk Inventor 2012 running on Windows 7, what can I do to solve this? Do I need to perform a clean install? Thanks un advance.
8 REPLIES 8
Message 2 of 9
I am assuming that you want to make a frame with profiles from the content center..
Can you enter to the content center in the assembly enviroment?
Message 3 of 9
No, I'cant open the Insert Frame Window. What should I do?
Message 4 of 9
Try creating a new assembly file, and insert any part from the content center..
If an error windows appears, I believe that this is because you didnt installed the content center of Inventor.
If you go to add/unistall programs in windows 7, you should be able to see the "Autodesk Inventor Content Center library¨¨
Message 5 of 9
I'll do that, but I don't know why happened this, I have been working without any problem.
Message 6 of 9
In add/uninstall programs, I can see the "Autodesk Inventor Content Center Libraries 2012 (Desktop Edition)", I don't know what to do...
Message 7 of 9
Are you using VAULT?
Message 8 of 9
Hi there, I'm not using Vault, I'm using Inventor Desktop Content.
When I browse to the path, I can see the large files in there, but Inventor doesn't recognize them...
Message 9 of 9
I repaired the Inventor 2012 and this solved the issue, this application is buggy as expensive.
Technology Administrators
