Raster Design OCR issues
DGRL
DGRL
Dear forum members,
I have a question about Raster Design 2016 for AutoCAD 2016
Can someone explain to me why OCR text is not working at all?
Please see screenshot
It recognizes the text correctly but the OK button WILL ALWAYS BE greyed out
Hope someone knows
Best regards,
If this was of any help please kudo and/or Accept as Solution
Kind Regards
Otto
Hello DGRL
It looks like you're seeing a grayed out button when attempting to register and activate your product. This issue typically occurs because Internet Explorer is either blocking or cannot connect to Autodesk registration servers. Access to Autodesk services is blocked by either IE, network, or proxy server security settings. The following article(s) should help you resolve the problem:
Register Today (Product Activation Wizard) blank except for two radio buttons
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Mark.Lancaster
@DGRL
This forum is for installation and licensing issue not a way to seek assistance for a given Autodesk product.  I will have your posting move to the correct forum.
Mark Lancaster
DGRL
hI @Mark.Lancaster
Thanks for this
I was browsing different forums and I switched to autocad to place this thread
As I wanted to post it it gave a red flag that I needed to give title
Parently it also changed the forum section as I did no tnoticed this
Anyway thanks for changing it to the correct one
Kind Regards
Type a product name
