Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
i am trying to make a thermal simulation. I drew heatsink and all other components, but when i switch from Design, where all is at place, to Simulation, all my components and joints ****fts to random position. Is problem at my side ? Thank you
Solved by jeff_strater. Go to Solution.
you will have to share your design here for more help. Do you have an pending "Capture Position" in your toolbar in Design?
actually, this turned out to be a legitimate bug. We have a fix, and it should appear in an update soon. Thanks for reporting it.
Also reported here: https://forums.autodesk.com/t5/fusion-360-support/joints-not-working-in-simulation/m-p/9384218
