Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
SheetMetal - Flange Creation fails with UNDEFINED ERROR
7 REPLIES 7
Message 1 of 8
624 Views, 7 Replies
As shown in the screencast, I get the message "UNDEFINED ERROR".
The Message "UNDEFINED ERROR" does not help a lot.
I don't have a clue what is wrong.
Can you please improve that error message?
7 REPLIES 7
Message 2 of 8
pawel.potyrala
Hi @Anonymous,
thanks for posting and sharing the screencast!
Would you be able to send me a link to the design? I would like to test it to figure out why the flange creation is failing.
If you do not want to post it here, you can send it to me in a private message. Thanks!
Best regards,
Paweł Potyrała
Technical Support Manager
Global Product Support
My Screencasts | Fusion 360 Webinars
Message 3 of 8
in reply to: pawel.potyrala
Hi Paweł,
I can share the design, its attached to this post.
Thanks for your effort.
Message 4 of 8
TheCADWhisperer
I was able to get this hybrid modeling technique to work.
Message 5 of 8
in reply to: TheCADWhisperer
Thank, that looks good!
It generates a nice flat panel 🙂
Where do I find that extrude(?) command you used? Is it the regular extrude? If yes, how do I select single lines instead of a closed contour?
Message 6 of 8
TheCADWhisperer
In the Surface Modeling tools.
Your entire part could have been simplified a bit, but I just used what you presented.
Message 7 of 8
Here's another way creating 4 flanges then combine.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 8 of 8
pawel.potyrala
Hi @Anonymous,
thank you once again for reporting this. I reached out to our developers with a request to change the produced error message to be more specific.
@HughesTooling @TheCADWhisperer thank you for providing the workarounds!
Best regards,
Paweł Potyrała
